    abs error code's
    edy333Datums: Otrdiena, 30.03.2010, 13:10:57 | Ziņojums # 1
    View Profile
    1992-1996 Honda Prelude ABS Error light indicator codes.
    « on: October 26, 2008, 08:58:53 AM »
    These are light flash indicator codes for the ABS system.
    My ABS light stays on and I'm thinking it's a dusty sensor on the front wheel.
    When you turn the vehicle on, the ABS light normally comes on, then goes out.
    When there is an error, the light stays on and after X number of seconds after starting, there is a light that flashes indicating what the error is.
    There is a good write-up here
    http://www.preludezone.com/showthread.php?p=154908
    10- ABS Pump Motor Over-run} Solenoid ABS Pump Motor Pressure Switch
    12- ABS Pump Motor Circuit Problem} ABS Motor Relay, ABS Unit Fuse, ABS Motor Fuse
    13- High Pressure Leakage}Solenoid(s)
    14- Pressure Switch
    18- Accumilator Gas Leakage
    21- Parking Brake Swith Related Problem} Brake Fluid Level Swtich, Brake System Light
    31- Pulser(s) (FR)} Wheel Sensor Installation
    32- Pulser(s) (FL)} Wheel Sensor Installation
    34- Pulser(s) (RR&L)} Wheel Sensor Installation
    41- Wheel Sensor (FR)
    42- Wheel Sensor (FL)
    44- Wheel Sensor (RR)
    48- Wheel Sensor (RL)
    50- Wheel Sensor(s) (RR&L)} Modulator Rear Brake Drag
    54- Wheel Sensor(s) (RR)} Modulator Rear Brake Drag
    58- Wheel Sensor(s) (RL)} Modulator Rear Brake Drag
    60- Fail-Safe Relay (F&R)
    61- Fail-Safe Relay (F)
    64- Fail-Safe Relay ®
    71- Solenoid Related Problem (FR)} ABS B1 Fuse
    72- Solenoid Related Problem (FL)} ABS B1 Fuse
    74- Solenoid Related Problem ®} Rear Fail-Safe Relay
    edy333Datums: Otrdiena, 30.03.2010, 14:38:52 | Ziņojums # 2
    man bij 12 kods, nomainiiju releju un viss bumbās... :P
