Error kodi!
| arturs001 | Datums: Svētdiena, 11.01.2009, 00:11:38 | Ziņojums # 1 |
| Here is the list of codes taken from the Honda Workshop Manual 0 Engine Control Module (ECM) 1 Heated Oxygen Sensor (HO2S) 3 Manifold Absolute Pressure (MAP SENSOR) 4 Crankshaft Position (CKP SENSOR) 5 Same as above 6 Engine Coolant Temperature (ECT SENSOR) 7 Throttle Position (TP SENSOR) 8 Top Dead Centre Position (TDC SENSOR) 9 No. 1 Cylinder Position (CYP SENSOR) 10 Intake Air Temperature (IAT SENSOR) 12 Exhaust Gas Recirculation (EGR VALVE LIFT SENSOR) 13 Barometric Pressure (BARO SENSOR) 14 Idle Air Control (IAC VALVE) 15 Ignition Output Signal 16 Fuel Injector 17 Vehicle Speed Sensor (VSS) 20 Electric Load Detector (ELD) 21 Variable Valve Timing & Valve Lift Electronic Control (VTEC) Solenoid Valve 22 Variable Valve Timing & Valve Lift Electronic Control (VTEC) Pressure Switch 23 Knock Sensor (KS) 41 Heated Oxygen Sensor (HO2S) Heater 43 Fuel Supply System
| Valcho | Datums: Svētdiena, 14.06.2009, 17:53:04 | Ziņojums # 2 |
| Kads var pastastit, ko isti nozime (7 Throttle Position (TP SENSOR) Un kas man butu jataisa?
| arturs001 | Datums: Pirmdiena, 15.06.2009, 07:51:05 | Ziņojums # 3 |
| Ieej te un Tur bilde ir paradits kur Tas sensors atrodas
Ziņojumu laboja arturs001 - Pirmdiena, 15.06.2009, 19:34:55 |
| WhiteAngel | Datums: Pirmdiena, 15.06.2009, 09:08:50 | Ziņojums # 4 |
| nja man viss skaidrs jau sen bija - koliidz kodu nolasiiju. Taatad tas senesors jamaina....
| Valcho | Datums: Pirmdiena, 15.06.2009, 19:01:32 | Ziņojums # 5 |
| Tatad jamaina sensors! Kur nez tadu var dabut, jamekle srotos? Cik tads nez maksa?
| arturs001 | Datums: Pirmdiena, 15.06.2009, 19:28:09 | Ziņojums # 6 |
| Man tads ir,bet no f20...Kads tev motors?Ja 2.0 tad varu tev notirgot!Ja kas PM
| kasiks | Datums: Sestdiena, 28.11.2009, 21:18:11 | Ziņojums # 7 |
| hmm, ko nozīmee, ja taa lampinja deg? peec tam kad savieno stekeri ar jumperu?
| edy333 | Datums: Sestdiena, 28.11.2009, 22:47:55 | Ziņojums # 8 |
| kura no lampiņām un kuru štekeri savienojot? Quote (kasiks) hmm, ko nozīmee, ja taa lampinja deg? peec tam kad savieno stekeri ar jumperu? dry
| kasiks | Datums: Sestdiena, 28.11.2009, 23:21:25 | Ziņojums # 9 |
| deg Check Engine lampinja, savienojot to 2pin service stekeri, kurs ir zem taas vidus konsoles. tas ir veicot diagnostiku
| edy333 | Datums: Sestdiena, 12.12.2009, 14:16:42 | Ziņojums # 10 |
| tas nozīmē, ka tev jāskaita garie un īsie signāli, gala rezultātā garie signāli apzīmē desmitus, bet īsie vienus... teiksim man bija 2 gari un 3 iisi, tas nzoiimee 23 kods..
| kasiks | Datums: Ceturtdiena, 17.12.2009, 01:18:42 | Ziņojums # 11 |
| jaa taa arii buus, pabraucot kaadu gabalu, iedegas Lampina, nolasiiju - 12. kods taatad EGR vaarsts. Vajadzees kaadu dienu to nonemt un iztiriit. Varbuut kaads var pateikt, vai vajag mainiit tos pulkiisus, kas ir iepluudes kolektoraa, tie arii attiecas uz gaazu recirkulaacijas sisteemu? Kopaa manupraat tie ir 6.
| edy333 | Datums: Ceturtdiena, 17.12.2009, 10:00:57 | Ziņojums # 12 |
| nu es domāju, ka īpaši jau tev neizdosies vecos iedabūt iekšā, kur nu vēl ārā izdabūt nesaņurcot......tā, ka jaunus vien vajadzēs...
| Hariiic | Datums: Trešdiena, 10.03.2010, 12:08:51 | Ziņojums # 13 |
| Hei sveika tauta! Pastāstiet ko īsti nozīmē 5 un 4 kods  Pievienots (10.03.2010, 12:08:51) --------------------------------------------- Nezinu kā ir ar šiem error kodiem, bet pēc autodata viņi atšķiras, un diezgan ilgi nočakarējos meklējot neīsto problēmu. Paskatoties autodata viensdivi novērsu viņus.
| themarchello | Datums: Trešdiena, 10.03.2010, 12:17:43 | Ziņojums # 14 |
| iekopeee Autodata Error kodus... noderees!
| Hariiic | Datums: Trešdiena, 10.03.2010, 12:22:01 | Ziņojums # 15 |
| Es jau labprāt, bet no datas nevar nokopēt.
