Помогите по Электрике!!
| Forget-me-Not | Datums: Ceturtdiena, 12.06.2008, 18:59:39 | Ziņojums # 1 |
| Я не знаю может предохранитель полетел, но: Неработает прикуриватель, салонная лампочка и подсветка багажника. Воть ;(
| MAYDAY | Datums: Ceturtdiena, 12.06.2008, 19:39:35 | Ziņojums # 2 |
| 5 - Not Used 6 - 15 Amp Seat Heater System (Canada) 7 - 30 Amp Sun Roof Open Relay, Sun Roof Close Relay 8 - 10 Amp Daytime Running Lights Control Unit (Canada) 9 - 15 Amp Heater Control Panel, Power Mirror System, ABS Control Unit, 4WS Control Unit, Fan Timer Unit, Mode/Recirc. Control Motor Heated Mirrors (Canada) 10 - Not Used 11 - 10 Amp Seat Heater Main Relay (Canada), A/C Compressor Clutch Relay, PGM-FI, ECU, Rear Window Defogger Relay 12 - 7.5 Amp Daytime Running Lights (Canada) 13 - 10 Amp Gauge Lights, Indicator Lights, Clock, Back-Up Lights 14 - 7.5 Amp Cruise Control System 15 - 20 Amp Driver's Power Window System 16 - 20 Amp Passenger's Power Window System 17 - 30 Amp Windshield Wiper System 18 - 10 Amp Stereo Radio/Cassette Player, Cigarette Lighter 19 - 15 Amp (Without SRS) (1992) Not Used (1993-94) PGM-FI Main Relay, A/T Control Unit, Fan Timer Unit, ELD Unit 20 - Not Used 21 - Not Used 22 - 10 Amp 4WS Control Unit, 4WS Front & Rear Steering Angle Sensors 23 - 15 Amp SRS Unit, Transmission Control Module (TCM), PGM-FI, Radiator Fan Control Module, Vehicle Speed Sensor (VSS), Charging System 24 - 10 Amp SRS Unit UNDERHOOD FUSE & RELAY PANEL IDENTIFICATION (1992-94) FUSES & CIRCUIT BREAKERS Article Text (p. 4)1993 Honda PreludeFor Cadi Centre Nsk CA 95051Copyright © 1998 Mitchell Fig. 2: Underhood Fuse & Relay Panel Identification (1992-94) Courtesy of American Honda Motor Co., Inc. WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician. 31 - 50 Amp ABS Motor Relay 32 - 100 Amp Power Distribution 33 - 50 Amp Ignition Switch (BAT) 34 - 40 Amp Rear Window Defogger Relay 35 - 40 Amp Blower Motor Relay 36 - 40 Amp Seat Heaters (Canada), PGM-FI Main Relay, Fog Lights (1994) 37 - 40 Amp Sun Roof System, Power Window System, Added (12.06.2008, 19:39:35) --------------------------------------------- Smotri v salone predohranitelj!!! A nash4ot lampo4ek- prosta zaeni na novie.
Ziņojumu laboja MAYDAY - Ceturtdiena, 12.06.2008, 19:40:14 |
| Forget-me-Not | Datums: Piektdiena, 13.06.2008, 19:15:20 | Ziņojums # 3 |
| Лампочки менял. Результата- 0. А где все предохранители?
| PITBULLS | Datums: Sestdiena, 14.06.2008, 09:04:24 | Ziņojums # 4 |
| Predohroniteli nahodjatsa v salone , rjadom s richagom otkrivanija kapota - tam jestj takaja zhe ruchka , kak na bardachke !!!
| Meph | Datums: Otrdiena, 24.06.2008, 20:40:39 | Ziņojums # 5 |
| Hmm.... A pomoemu pod kapotom? S levoj storoni erhu (esli stojat' licom k lobovomu steklu)... Pitbull ili ja oshibajus'?
| PITBULLS | Datums: Trešdiena, 25.06.2008, 08:42:42 | Ziņojums # 6 |
| Neznaju , u mojei IV jestj i tam , i tam !
| MAYDAY | Datums: Trešdiena, 25.06.2008, 13:16:54 | Ziņojums # 7 |
| Droshinaataaji visaam Preluudeem atrodas, gan salonaa(vadiitaaja pusee), gan arii zem motora paarsega labajaa augsheejaa stuurii.
