    Помогите по Электрике!!
    Forget-me-NotDatums: Ceturtdiena, 12.06.2008, 18:59:39 | Ziņojums # 1
    Я не знаю может предохранитель полетел, но:
    Неработает прикуриватель, салонная лампочка и подсветка багажника. Воть ;(
    MAYDAYDatums: Ceturtdiena, 12.06.2008, 19:39:35 | Ziņojums # 2
    5 - Not Used
    6 - 15 Amp
    Seat Heater System (Canada)
    7 - 30 Amp
    Sun Roof Open Relay, Sun Roof Close Relay
    8 - 10 Amp
    Daytime Running Lights Control Unit (Canada)
    9 - 15 Amp
    Heater Control Panel, Power Mirror System, ABS Control Unit,
    4WS Control Unit, Fan Timer Unit, Mode/Recirc. Control Motor
    Heated Mirrors (Canada)
    10 - Not Used
    11 - 10 Amp
    Seat Heater Main Relay (Canada), A/C Compressor Clutch Relay,
    PGM-FI, ECU, Rear Window Defogger Relay
    12 - 7.5 Amp
    Daytime Running Lights (Canada)
    13 - 10 Amp
    Gauge Lights, Indicator Lights, Clock, Back-Up Lights
    14 - 7.5 Amp
    Cruise Control System
    15 - 20 Amp
    Driver's Power Window System
    16 - 20 Amp
    Passenger's Power Window System
    17 - 30 Amp
    Windshield Wiper System
    18 - 10 Amp
    Stereo Radio/Cassette Player, Cigarette Lighter
    19 - 15 Amp (Without SRS) (1992)
    Not Used (1993-94)
    PGM-FI Main Relay, A/T Control Unit, Fan Timer Unit, ELD Unit
    20 - Not Used
    21 - Not Used
    22 - 10 Amp
    4WS Control Unit, 4WS Front & Rear Steering Angle Sensors
    23 - 15 Amp
    SRS Unit, Transmission Control Module (TCM), PGM-FI,
    Radiator Fan Control Module, Vehicle Speed Sensor (VSS),
    Charging System
    24 - 10 Amp
    SRS Unit
    UNDERHOOD FUSE & RELAY PANEL IDENTIFICATION (1992-94)
    FUSES & CIRCUIT BREAKERS Article Text (p. 4)1993 Honda PreludeFor Cadi Centre Nsk CA 95051Copyright © 1998 Mitchell Fig. 2: Underhood Fuse & Relay Panel Identification (1992-94)
    Courtesy of American Honda Motor Co., Inc.
    WARNING: Always disconnect battery ground cable before servicing
    "high-current fuses. It is recommended that "high-current"
    fuses be replaced by a qualified technician.
    31 - 50 Amp
    ABS Motor Relay
    32 - 100 Amp
    Power Distribution
    33 - 50 Amp
    Ignition Switch (BAT)
    34 - 40 Amp
    35 - 40 Amp
    Blower Motor Relay
    36 - 40 Amp
    Seat Heaters (Canada), PGM-FI Main Relay, Fog Lights (1994)
    37 - 40 Amp
    Sun Roof System, Power Window System,
    Added (12.06.2008, 19:39:35)
    Smotri v salone predohranitelj!!! A nash4ot lampo4ek- prosta zaeni na novie.
    Ziņojumu laboja MAYDAY - Ceturtdiena, 12.06.2008, 19:40:14
    Forget-me-NotDatums: Piektdiena, 13.06.2008, 19:15:20 | Ziņojums # 3
    Лампочки менял. Результата- 0.
    А где все предохранители?
    PITBULLSDatums: Sestdiena, 14.06.2008, 09:04:24 | Ziņojums # 4
    Predohroniteli nahodjatsa v salone , rjadom s richagom otkrivanija kapota - tam jestj takaja zhe ruchka , kak na bardachke smile !!!
    MephDatums: Otrdiena, 24.06.2008, 20:40:39 | Ziņojums # 5
    Hmm.... dry A pomoemu pod kapotom? S levoj storoni erhu (esli stojat' licom k lobovomu steklu)...
    Pitbull ili ja oshibajus'? surprised
    PITBULLSDatums: Trešdiena, 25.06.2008, 08:42:42 | Ziņojums # 6
    Neznaju , u mojei IV jestj i tam , i tam wacko !
    MAYDAYDatums: Trešdiena, 25.06.2008, 13:16:54 | Ziņojums # 7
    Droshinaataaji visaam Preluudeem atrodas, gan salonaa(vadiitaaja pusee), gan arii zem motora paarsega labajaa augsheejaa stuurii.
